Ok ill try to explain this as easy as possible. I have been downloading serval movies off the net which are dvd divx rips. I want to take that .avi file and convert it to a dvd. I am wandering this because I used TMPGenc for one movie and selected the options in there for a dvdr. It took a while to encode and when I was finished making it into a .mpg I used Ulead DVD movie maker. Is this the only way to go from .avi to .mpg for dvd use?
Also do I need to use virtual dub to rip the audio in 48000? Then go to TMPGEnc and encode it from there.
I'm just a little confused right now an all of the steps that I need to do and the steps that are optoinal.
Since you already have the AVI file, use TMPGEnc. Load TMPGEnc Plus registered if your regular TMPGEnc is older than 14 days. Open the program, close the wizard if it opens. Load the DVD template with the Load function.
Select Start. The resultant file is ready for burning.Hello. -
I too have downloaded some Divx movies off the internet, but I have no idea how to convert them to a dvdr or vcd or whaterever works. I just want to know how to get a divx file onto something I can wiatch in my dvd player (which sipports vcd's) Any help? PLEASE!
I seem to be saying this a lot today.:
http://www.vcdhelp.com/newbie
http://www.vcdhelp.com/convert
http://www.vcdhelp.com/author
Start reading and have fun!
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
copy avi file from scratched dvdr
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2010, 01:14 -
problem converting from NTSC VHS to dvdr
By skywalker9999 in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 04:22 -
AVI file(s) too large for DVDR
By sybarite in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 20:35 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 05:09
