When i try to burn anything using Nero, it just says "simulation failed" but with Easy CD Creator it works perfectly. I want to use Nero because I've heard its better. Here are my system specs:
Windows ME
HP 8230E CD Writer
Intel PIII 733Mhz
256MB Ram
Anyone know?
Thanks,
Dhruv
Maybe Nero doesn't work when Easy CD Creator is installed too. Deinstall Easy CD creator before installing Nero. Check the Nero's website (www.ahead.de) if there are any known problems with Windows ME or your burner. Maybe your burner needs a firmware upgrade.
Regards,
Willem -
I had a similar problem. I would get an 'invalid command' when I tried to burn a vcd. I found, though, when I unchecked the 'disc at once' checkbox it would work. The 8230e, apparently, cannot handle the disc at once feature.
Hitler hates AMD Bulldozer
By deadrats in forum ComputerReplies: 0Last Post: 14th Oct 2011, 16:51 -
Argh. TDSS infection (Vista)
By Ai Haibara in forum ComputerReplies: 17Last Post: 4th Jul 2009, 11:15 -
Windows vista hates converting video??
By masadar in forum Video ConversionReplies: 4Last Post: 22nd Sep 2008, 03:18 -
stupidly finalized -rw dv mode (sony) now can't transfer to pc- argh!
By lwoodroff in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 12:43 -
Argh! More converting PAL to NTSC!
By Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2007, 19:56
