Two questions if you guys could help. Using the KVCD templates with TMPGE I have made several short clips in both vcd and svcd and I dont really notice a difference in picture/sound quality between them. Other than the larger file size of the svcd there is no difference. Is this normal?
Secondly the picture output seems kind of small on my tv, its not tall enough. My output file size is set at 704x576. Am I stuck with what I get?
Just some background. My source is divix and properties says its 576x240 25fps. I am using pal templates that are 704x576. My dvd player doesnt support scvd, so after encoding them I simple multiplex them in mpg1-nonstandard to get them to work. I burn both as vcd using nero and uncheck the compliance box. If it matters I live in the U.S. How screwd up am I?
John
You're not screwed up at all jrv331
You did the right thing. If your source is PAL, you encode with a PAL template. Just about every DVD player made will play NTSC or PAL VCD's. For playing back DVD's, that's another story, because of the region restrictions on the player. But this doesn't apply to VCD's. For your picture size, try using FitCD. This will calculate the correct output aspect so you encode with the correct resizing.
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
Output file is a mess - judder & interlaced....
By The.King in forum Video ConversionReplies: 6Last Post: 29th Jan 2011, 22:44 -
Audio/Video Selector & Output Quality
By Tom Saurus in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2010, 17:27 -
Blu-Ray output to older Yamaha amp
By Mister-Mike in forum DVD & Blu-ray PlayersReplies: 8Last Post: 14th Jan 2009, 00:13 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 08:19 -
Progressive vs. RGB output on upscaling DVD player & HD TV
By iansport in forum DVB / IPTVReplies: 5Last Post: 11th Jul 2008, 07:35
