My first DVD burning was last week; mini-DVD on regular CD-R. Worked perfectly. I just installed Ricoh MP5125A-DP, over firewire in enclosure. All went fine. Everything recognised. Tried to burn the same DVD as last week, this time onto actual DVD+RW. DVD Complete performed a successful burn, but the disk was then not recognised at all by either my stand alone player or by two different PCs. Data was written to the disk - I can see that - and DVD Complete claimed a successful burn. So I tried
again. Same deal; successful burn, no errors, but non-playable result. Before I waste a DVD+R can anyone shed any light? (I have DVD Complete Deluxe, on Win2K, 1000MHz, 512 RAM.)
Thanks.![]()
Many DVD players and DVD - rom drives cannot read DVD+RW (or any of the DVD recordable fomats). You can check you standalone players media compatibility in the DVD players list, look to the left column of this page.
Also, what were you using to author and burn the disk?
I have had trouble with specific programs like NERO and IFOedit that dissapear once I use SpruceUp or DVD workshop. -
Most likely your problem is authoring and how you set up your files in NERO. I had the same problems until I switched to ULead Movie Factory for authoring purposed. Now I have no problems at all.
Thanks guys.
I'm using DVD Complete (so no Nero). Last week I successfully burned a Mini-DVD on CD-R, which played perfectly on my three PC test possibilities but not, of course, on my standalone (well, the menus did, but not the movie).
I have now tried three times to burn the same movie (13 minutes) on DVD+RW with each time the same strange result; the disk plays back perfectly on the burner, but it is not even recognised as a disk at all on any PC or on the standalone (which does support most formats - it's a Panasonic DVD-RV32).
Any suggestions, anyone?
Thanks. -
Additional info:
I just tried a burn using Nero and got exactly the same result; it plays back fine in the burner, but not anywhere else. -
Check the compatability list on this web site. Most computer burners recognize many different types of formats that your stand alone wont. Also when burning in Nero, when you start a new prject, be sure to open the TS_Video file and place your VOBs in that or it won't work.
Used Deshaker on a footage, but bad result. Please help.
By namphong0612 in forum EditingReplies: 12Last Post: 11th Jan 2012, 22:13 -
Good or Bad ? at Verbatim 97016
By texmexdeaf in forum MediaReplies: 2Last Post: 13th Jun 2010, 01:03 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
FFmpeg options ? Bad result on a standalone
By Umen Pich in forum Video ConversionReplies: 4Last Post: 18th Jan 2009, 09:28 -
Burn DVD using DVDFab end result one file in iTunes?
By Kramer620 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:26
