I can rip DVDs, but the question is , is there anything out there that will split sound ?
What i want is to capture the voices (human sound)on a dvd , but get rid of the background music so i can multiplex and add my own sound ?
I dont know which software will do it, or if it is possible.
I am assuming that the sound on a dvd is multi channel, so i should be able to split it ??ß
any answers welcomed.
thanks in advance.
If you can rip the Ac3 soundtrack from a DVD you end up with a 5.1 channel sound. I think you could convert individual channels to wav format with Headac3he. Can't say I have ever tried it though.
hi
ripped a dvd , downloaded headac3he with all the bits, can see channels, but do you know how to split, because its not working.
thanks for the idea though -
In headac3he, click the options button and a new panel should appear. Under input channels, just select the cahannels you want in the output wav file, Left, Center, Right etc. Give the output file a name (eg movie_left.wav) and click start.
Using HJ Split
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 00:59 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Sound when split screen used
By gmc9960 in forum EditingReplies: 0Last Post: 8th Feb 2008, 06:20 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
