can i burn VCD movie on DVD+RW disc?
how?
Yes you can, VCD format is part of the DVD standard.
PAL
Video:
up to 9.8 Mbit/sec MPEG-2 or MPEG-1
720 x 576 pixels
352 x 288 pixels (VCD Standard) <<<<<<<<<<<<<<<
352 x 576 pixels (CVD Standard)
25 frames/second
Audio:
Up to 8 audio tracks containing Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer2 one track must either have MPEG-1 or DD or PCM Audio.
NTSC
Video:
up to 9,8 Mbit/sec MPEG-2 or MPEG-1
720 x 480 pixels
352 x 240 pixels (VCD Standard) <<<<<<<<<<<<<<<
352 x 480 pixels (CVD Standard)
29,97 frames/second
Audio:
Up to 8 audio tracks containing Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer2 but one track must either have DD or PCM Audio.
You must author it with a DVD authoring program like DVD Worksop or MyDVD. -
No.
However, VCD compatible MPEG-1 files are largely compatible with DVD so you can use it as the source for a DVD.
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by wizzy
mphearn: yes you can burn directly to vcd on cdr/w but not on DVD+R/W as wizzy waaaaants.
To burn vcd mpeg1 files as a dvd you should convert the audio to 48 khz and then you should be able to author and burn as standard dvd.
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 01:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
