I have split the DVD1 (to be burned on 2 dvd's) of the LOTR with IFOEDIT, and done all the things need to be done (read some tutorials) to make them ready to copy to DVD+R.
Test on PowerDVD results GOOD.
Start up Nero (version 55917...just updated). select DVDVideo (no multises.) try to write then Nero said
DVD-Video files reallocation failed. The resulting DVD-Video might be unplayable. Do you want to continue?
Yes of course i want to resulting that the DVD dont play........![]()
I'm a missing still something here ???
Thanks in advance for you help
Erwin
Chances are that it will play OK. You can avoid this error in Nero by burning your DVD-videos using UDF/ISO mode.
AFAIK the only real difference between UDF/ISO and dvd-video (in Nero that is) is that the DVD-Video version looks at the files being burnt (not their contents, just their filenames) and checks that all the files required a valid DVD-video are there and no others.
Hope this helps -
I've had this same error, the resolve I found was to use IFOEdit on the two directories (DVD's) independantly you've made, i.e. after you have split them.
Open IFOEDIT, and then [Create IFO].
You will be asked which VOB file you want to create VIDEO_TS.IFO, in this case navigate to the 1st VOB file of the set. IFOEDIT re-create 2 files VIDEO_TS.IFO and VTS_01_0.IFO
Close down IFOEDIT without saving.
Start IFOEDIT and open VIDEO_TS.IFO and click on [GET VTS SECTOR] and follow the suggestion until finish repeat this step with all IFO files in this directory. Close down IFOEDIT and again without saving.
Burn using DVD-Video mode of Nero and all is fine.
Ian.Home built:-
1.2GHz Athlon / 384mb ram / Full tower
AIW 8500DV
60gb & 120gb HD
Pioneer DVD- Writer, CDRW drives
Turtle Beach Santa Cruz soundcard -
Sorry IanJ but thatend worked for me.....but thanks for your help
I also did like bugster said and that works for me.....and that fixed
the problem for me........it works great.....so thanks
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
