  1. SVCD,VCD to DVD-R How To??
    How do i or can i burn s/vcd to a blank dvd-r cus nero tells me to use the right media is there any way around this??
  2. try looking to see what the site has to offer before jumping into ask questions!
    http://www.vcdhelp.com/svcddvdr.htm
  3. I've tried That it dont work at all..I've tried both methods
  4. Need more info. In waht way does it not work. If you succesfully author a DVD with SVCD using this method but your DVD player won't play it, then the only option is to re-encode to one of the standard DVD resolutions. From SVCD source I would suggest CVD which is 352*480 (576 for PAL). This is a valid resolution for DVD and should be accepted by all players.
