i just downloaded the 30 days trial from stompinc.com...it recognize my sony drive right away....woo hoooo....way to goo.....
Anyway..i'm looking for the link so we can upgrade from free for owner of sony drive
Results 1 to 14 of 14
Only RecordNow DX can be downloaded for free by Sony users,Originally Posted by Da Man
to replace RecrodNow which came with the drive.
RecordNow Max is a different product, which has not been promised by Sony. -
Where did you download it from on that site? All I could find was version 4.1 ...
It is not out until Nov 8th .. the above poster must have a beta copy or is just trying to stir up peoples blood pressure
Rest assured it is NOT out but will be on the 8th.
http://www.winplanet.com/winplanet/news/4520/1/
here is the link about the new version 4.5
The 30 days trial 4.5 file is named stpRNM450e_STPD.exe (9M)
The upgrade file to 4.5 is named stprnm450v.exe (15M)
Here is the readme file included in the 30 days trial
Stomp RecordNow MAX, Version 4.50
Copyright 2002 VERITAS Software Corp. All Rights Reserved.
This README.TXT file provides late-breaking information that
supplements Stomp RecordNow MAX on-line help. If information in help file conflicts
with information presented here, the information in this README.TXT file
should be considered correct and the most recent.
How to use this document
To view README.TXT on your screen in Notepad, maximize the
Notepad window.
To print README.TXT, open it in Notepad, WordPad, or another word
processor. Then select the entire document and format the text in
10-point Courier font before printing.
The following subjects are discussed:
1. Reading Audio Discs
2. Delay After Cancel
3. Copying CDs
4. Mastering Limitations
5. Conflicts with Easy CD Creator 4
6. Enable DMA to Reduce Buffer Underruns
7. Media Compatibility
8. Windows 98/ME does not read multi-session DVDs properly
9. Possible DVD data loss with Windows 2000/XP
If you create an Audio CD using a CD-RW disc, you will only be able to
play this disc on Multi-Read capable CD players. For best results, it
is recommended that Audio CDs be created using CD-R media.
For DVD players, please consult your DVD Owner's Manual in order to
determine which type of media will provide the best results.
A delay of a few seconds to several minutes may result after canceling
an operation. The length of delay will depend upon the drive model,
type of media used, and the point at which the operation was cancelled.
3. Copying CDs
Copying Audio CDs may take longer than copying Data CDs on some models of
drives. This will vary between models, and can be affected by the quality
of the source media.
Stomp RecordNow MAX can record files that contain file names up to
110 characters in length. This maximum length is a limitation of the
recording file system, and cannot be exceeded.
5. Conflicts with Adaptec Easy CD Creator 4
If you are using Stomp RecordNow MAX on a system containing Windows 2000 and Adaptec
Easy CD Creator 4, you may experience a conflict. You will not encounter this
problem if your version of Adaptec software is v4.02 or greater.
If you experience buffer underruns, try enabling DMA (Direct Memory
Access) on your computer. See your computer's documentation for
instructions on how to do this.
Some consumer disc players cannot read CD-R or CD-RW media.
If you are experiencing problems reading certain types of media,
please check your player's documentation to ensure that your
device is capable of reading the media.
Windows 98/ME systems can only read the first session recorded to an
appendable DVD disc. If you open an appendable
DVD on a Windows 98/ME system and some files appear to be missing, try
opening the disc on a computer running a different operating system.
Stomp RecordNow MAX allows you to make multiple recordings to a single DVD.
However, a serious problem can occur on Windows 2000 and XP systems
once the total amount of data or music recorded during multiple jobs
exceeds 4 GB. Once the total amount of data or music exceeds 4 GB,
only the first recording job placed on the disc will be visible to
your computer. This problem does not affect single recording jobs
larger than 4 GB.
Microsoft has been working to fix this problem. For more information,
please visit the Microsoft support center at
http://support.microsoft.com and search for document Q329112. -
here is the link to download the 30 days trials record now max 4.5 and the upgrade 4.5
http://downloads.stompinc.com/files/stpRNM450e_STPD.exe
http://downloads.stompinc.com/support/stprnm450v.exe
Who the bitch now. -
You have my sincere apologizes .. The manufacturer said the 8th, and they are still saying the 8th, and it is not directly avail via the website, that is the information I was going on which should have been reliable
4.5 was there this morning, now they have gone back to showing onlyOriginally Posted by Websteria
the upgrade to 4.1 on the site.
Luckily someone here was nice enough to post a direct link to the 4.5 upgrade.
Worked for me 10 minutes ago
yea...i'm the one who posted the direct link...i dl it last night....when i when back today..the link gone but i still can dig it out in my browser history...enjoy
Share the wealth...
Andy -
Thanks again Andy!Originally Posted by Da Man
It was there at one point this morning.
I wonder why they removed it though; I hope there wasn't something wrong with it (such as a major bug that got past the QA testing phase). -
I have the trial version of record now max 4.5 (now i`m going to be cheeky here) but
is there anywhere you can get the full version download for free.........
http://dl1.easy.co.jp/rndx46_e/sonyos/program/rndx46_en.zipOriginally Posted by marianne
RN DX = RN MAX -
Get RecordNow Max 4.5 for FREE
Download the upgrade version of Stomp RecordNow Max 4.5 from here:
Open the stprnm.exe file in winzip, then extract the files to a folder.
Goto that folder and find a file called Setup.ini. Open this file in notepad. Delete all these lines, then save the file.
[UpgradeConditions]
{8855FF30-19CE-4CB1-A654-87B38369CCE1},,,STP;STU;STF,VERITAS\RecordNow DX\CurrentVersion\All\Wizard
Then double click setup.exe file and install the program.
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 14:53 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum Capturing and VCRReplies: 3Last Post: 2nd Nov 2008, 15:59 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02 -
No Sony BR Authoring Support
By SCDVD in forum Authoring (Blu-ray)Replies: 26Last Post: 28th Mar 2008, 00:59
