Every now and then during the day my monitor just goes black and flashes "DPMS Off Mode" and then flashes "DPMS Suspend Mode". This happens all the time. I always have to reboot to get the picture back. Somebody saids that my video card is shutting down. Well what do I do to fix this? I tried reinstalling the drivers and it still occurs.
Hi,
Does the PC stay on, or is this turned off too ?
I had a cheap power suply once, that couldn't handle the power peaks on the power net very wel, causing it to turn off the PC every now and then.
If the PC stays on, try using another videocard or your card in another PC if you have the possibility.
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success !
PC or monitor?
By Jomapil in forum ComputerReplies: 11Last Post: 16th Oct 2009, 11:08 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Need New Monitor
By mccoady in forum ComputerReplies: 13Last Post: 7th Mar 2008, 16:33 -
Use DV as second monitor?
By boyerama in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:38 -
Monitor
By JonathanK in forum AudioReplies: 2Last Post: 13th May 2007, 17:15
