I was using the guide "Getting the best out of CCE" from Doom9. I got all the way to the end of it, but now Tmpgenc will not accept my .avs file to encode the audio. I have tried everything (or so i think) Tmpgenc recognizes .avs files, but when i try to open them, it says "Floating decimal point divided by zero", then "file unsupported", etc....
I found a previous post in the forums dealing with this, but i couldnt get anything to work? Any other ideas? Is their another program i could use to encode the audio from my .avs instead of dealing with Tmpgenc? Thanks in advance!!
Ok, i was just thinking....when following the guide i used, in the .avs script, you are supposed to insert the line "ResampleAudio(44100)"
It says this is used to trick CCE into thinking their is an audio track in the file. How do i encode the audio then, if it isnt actually in the .avs script??
~Now i am really lost!!! Could someone please point me in the right direction.......
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Help with audio encoding
By tooonami in forum LinuxReplies: 1Last Post: 11th Jul 2009, 18:55 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
