...Hi guys - trying to back up my copy of the special edition of Brian DePalma's "Dressed to Kill" - problem is this - I just want the movie, no more, but this disc allows you to play either the theatrical release or the un-rated version. Somehow both versions are mingled so when I rip the movie VOBs, the scenes that differ between the rated and unrated versions are shown one after the other within the film, which otherwise is fine, if that makes sense - is there some sort of playing around I can do with IfoEdit or should I just give up?
Rgds,
JeffC![]()
a long winded solution.. ignore the fact that those parts are there for now and encode the whole movie as normal. then cut and join the file so you remove the scenes that you don't want.
just an idea
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
Fair suggestion! I did also think that I could possibly rip the menu's and maybe with a bit of pointer re-jigging through IfoEdit I could just squeeze the menu (with "rated/unrated version" choices) and the movie itself onto a disc... I'll have a go...
JeffC
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 03:31 -
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 05:30 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 07:51 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 09:12 -
Blu-Ray "special editions" coming?
By ryangarfield in forum Off topicReplies: 6Last Post: 15th Mar 2008, 07:03
