  1. im im urgent help of something im quite sure is easy solved.
    if i have a *.img file or a *.bin file which is below 4 gb which certain dvd players wont read how do i solve that matter so it get above 4 gb
  2. dvddecrptor will burn it to a dvd 4 U!! hopefully!
    Kev!
  3. what the hell is a bin file?thought that related to
    burning games,if you wanna burn dvd-r,you
    better get use to using vob files in VIDEO_TS
    folders
  4. bin is a binary file suchas a *.img or *.nrg simply n image file
  5. Originally Posted by P@iNKilleR
    Kev!
    could u type that name again cause it looked kinda weird or is that how it is spelled ??
    thx for the help
  6. sorry at the time I was sort of tired!! ok the program is dvd decryptor & U will be able to get it from the tools section... this should atleast be able to burn the image file as it supports Bin files.
    Kev!
  7. the problem isnt to actually burn it that i can do with programs suchas nero but if the dvd file end up beein smaller then 4 gb then my dvd player wont read it now.. thats my problem how to add perhaps n xtra file into it or something else that makes it larger then 4gb
