I just got Spiderman and after i rip it i try and play it with Power DVD and i get no sound... is this from the rip or is this the PowerDVD Player?
did u rip just the movie or the whole dvd.?
make sure if u just ripped the movie u got the necessary audio streamscheck out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
Originally Posted by destro_99
Late post I know but destro_99, did this ever work for you ? I'm having the same problem.
If you just ripped the movie VOBs then try skipping to the 2nd VOB.
I have had this problem several times. The sound is sometimes missing in the first VOB but remaining VOBs are fine.
If this is the case let me know and I'll give the solution that I came up with. pressed 4 time at the moment -
AC5.1 is not standard for standard Power DVD. It's an upgrade. If you ripped it to Harddrive, you probably have just the (English) AC5.1 stream. I rolled back to an older version that supports 5.1 instead of the new version that I had to buy an upgrade for. Try a different player (like Media Player classic, no installed involved).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 14:46 -
DVD Decryptor with newer protection schemes?
By Huh...What? in forum DVD RippingReplies: 7Last Post: 26th Aug 2010, 08:34 -
DVD Decryptor Error Massage
By pchan in forum DVD RippingReplies: 13Last Post: 18th Jun 2009, 13:37 -
Problems in different equipment with .mpeg1 in Power Point
By carlosarano in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 09:25 -
Power problems with Canadian Xbox 360 is Australia
By ryangarfield in forum Off topicReplies: 3Last Post: 15th Feb 2009, 03:04
