  1. I'm tyrying to convert a 33min file into a Svcd using Tmpgenc. I constructed the video using ado Premiere 6.0 and saved it using the MiroVideo DC30 M-Jpeg[16]. When I try convert it using Tmpgenc all I get it a blank screen with audio. What can I do to get it to work.
    Dec 2000
    Some airport, somewhere..
    Try frameserving the video directly to TMPG using AviSynth.
  3. I'm trying to keep the frame rate at 29.97. Plus when I fileserve it to Tmpgenc with avisynth it freezes.
    I've tryed another codec, divx, but it leaves it with too many artifacts.
  4. Member vhelp's Avatar
    Mar 2001
    New York
    How about,,,
    1) options/environment settings/VFAPI plug-in/
    2) and then right-click the AVI field and select "Higher priority"
    (try both the AVI fields) till it works. Useusally, i keep selecting
    (right-clicking) the AVI field till it goes to the top, and then
    proceed to encode video. (you should begin seeing the avi file
    display in TMPGEnc's window - hopefully)**
    3) let us know if it worked!!
    ** I use the dc10+ mjpeg card, and this happens to me too.
    After doing the above steps, I can see my avi video in the window
    and proceed to encode. Should work for you!
    Later.
  5. It worked. Thanks alot. I appreciate it very much.
