Any recommendations for progressive scan DVD players with
a hack available for disabling macrovision ?
couldn't find any in the hack list.
How are you going to record Progressive Video from DVD ?
The 480P output is only available in component Video ( 3 RCA connector ).
Do DVD recorder like panasonic takes progressive video ? -
At this point, I wasn't planning to record in progressive scan..
I want to be able to record occasionally in VHS format..
but view DVDs that I rent in progressive scan on my Samsung 42" progressive scan TV (HD capable monitor).
But later, yes.. if progressive scan recording becomes cheaper.. I presume I can do it in a D-VHS recorder today as it can record HDTV.. I will want to use that option - after a year hopefully.. when D-VHS recorders drop below $400! -
The lists are ALL WRONG! I checked me Pioneer out.It says no hacks,and priced at $80? You click on the more info,and lowest price is about $300.It should be about $250.Also I know there were hacks posted a couple of months ago.
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 16:22 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 12:52 -
Progressive Scan for DVDs
By KayAt in forum Newbie / General discussionsReplies: 9Last Post: 25th Nov 2008, 21:30 -
Progressive scan problem
By Deaner777 in forum Authoring (DVD)Replies: 0Last Post: 28th Jul 2008, 15:23 -
Confused about progressive scan
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2007, 12:28
