I looking for a mpeg2 capture that can capture directly to complient DVD mpeg2 streams.
looking for good qality mpeg1/VCD capture also.
would be perfect if it also capture with 3rd party cap program like Virtual Dub. not just it's own propieritory program
any suggestions? link to the reviews would be helpful too. thanks
Unless you want to spend thousands I would get a normal Capture card and do the mpeg2 conversion myself. the low budget mpeg2 capture cards ($100-$300 range) aren't all that good, Converting with cce orTmpeg look alot better.
I was looking at the WinTV PVR 250 and I found 2 reviews on it from SKittens and I think Bitech.
I already own the WinTV FM card and I'm happy with their product.
my only question remains is wil lthe wintv PVR 250 work with the likes of Virtual Dub? -
Any of the Vidac Vmagic will do (S)VCD and DVD mpegs with good quality. They will not work with capture programs other than the program that comes with the card though.
While surfing I found this PCI card fom KWorld that says it does hardware Mpeg1 and Mpeg2.
http://www.compgeeks.com/details.asp?invtid=MP2PCI-TV -
The Kworld DVD maker is similar to the following cards:
Provideo (256T): http://www.provideo.com.tw/PV256.htm
Aviosys (DVD PLUS 3020): http://www.aviosys.com/3020e.htm
I got the Kworld DVD maker TV but I use it with the Provideo 256T drivers.
For reviews and support go to http://www.iln.com.au/pv256.html
Otto
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 15:56 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 05:50 -
need capture card recommendation
By mysts in forum Capturing and VCRReplies: 3Last Post: 30th May 2010, 19:52 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 13:39 -
laptp capture card recommendation
By theduffer in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2008, 09:26
