Help please...
I installed a video capture card but the sound wont capture.. I try researching the problem on the internet.. the only help I found said this:
"..First, check that you aren't missing the pass-through. Most video capture cards don't have on-board sound capture and instead use your sound card, so if you don't connect the cable from the capture board to the sound input, you won't get any sound."
OK, so can anyone tell me WHAT CABLE to WHAT SOUND INPUT??
I think this is a basic instalation question that someone here can answer.
I am trying to do this for a friend, I told her to post her problem here, but she got no replies.. Hopefully I am asking the question clearly
The card she bought is a LGV-5480TVR
I could find no info on the internet about it, but a picture of the card and its specifications are shown here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2067488385
I know this is a cheap card, but she will only be doing some very basic video capture with it and it should serve her purpose just fine if only the sound capture could be configured.
Would really appreciate anyones help on this.
If it's anything like mine, it's just a short (1/8" plug?) cable that connects your capture card to your sound card input (line in). Some folks just skip it and plug directly into their sound card....Originally Posted by end80
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 10:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 18:35 -
Capture card problem
By Phaze72 in forum Capturing and VCRReplies: 7Last Post: 13th Apr 2008, 18:31 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
