I'm having trouble playing this certain file. All I get is sound not picture . When I checked what codec it used it said DIV4 so then I downloaded divx 3.11 alpha but it still didn't work.Which divx codec should I use to play this file?
You should download something like Gspot (link available in the Tools section of this site) that will identify the AVIs you are trying to play. This will tell you for sure what codec was used.
Which codec?
By Andyncu in forum Video Streaming DownloadingReplies: 5Last Post: 13th Feb 2011, 09:11 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
which codec
By peterg60 in forum Video ConversionReplies: 6Last Post: 25th Jul 2007, 16:52
