Hi all. Thanks to Baldrock's DVDit tutorial, I managed to create my own DVD last night. Then I tried putting it in my PS2 to watch it. I should have known better...
So as you all might have guessed, I'm looking for a DVD Player. From the reviews on this site, the Apex AD-5131 seems to be the do-all player, with a great price. I've also searched through the forums, and found information on the firmware hacks, problems with the remote, and more importantly, discrepencies in the Serial #.
I am wondering, will the SN# make a big difference on the firmware upgrade (i.e. possible/impossible), or is it just the same no matter what SN# I'll have on my Apex? I was going to ask if there's a way to check the serial # before buying, but the only way I could think of is to go into the store itself, instead of buying online. Kind of tough for me since I work in NJ, don't get into NY until about 8:00, and J&R closes 7:30.![]()
If anyone has an idea, I'd appreciate any input. I also want to thank you all for the great information I was able to look through via search (links to www.nerd-out.com, firmware updates, compatibility). Now instead of wondering about 5 different issues, I'm only wondering about 1. Thanks.
Results 1 to 1 of 1
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 11:11 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 23:38 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 19:39 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33 -
Filter order matter in editing?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jun 2007, 17:54
