I have a lot of music dvds and want to copy all the tracks to a CD so I can use it in a normal CD player.
Anyone that has a solution? Last time i poted this I had 120 views but no answer, could it be that tricky?
Here ya go, it will allow you to watch it and put it in your cd player to listen to it.
Its a solution
http://www.vcdhelp.com/forum/viewtopic.php?t=113432
Another suggestion would be to rip the dvd - then use dvd2avi to create a wav file of the dvd and then you can record that wav file using audio cd and it will play in your cd player. -
Better rip the DVD by chapter, then dvd2avi.
Or else you willhave to edit the section you want in
a sound editor, which is a pain.
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 19:15 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 13:02
