For the past 3 days (on and off), I've been struggling with backing up Goodfellas. The DVD is two-sided. Both sides copy OK with CLAD. Both sides go through TMPGenc fine. When I use SpruceUp on part 1, I get an error towards the end (99%). Part 2 spruces fine.
As a result, not all the files in VIDEO_TS are there in part 1.
I have also tried joining parts 1 and 2 in TMPGenc and doing a single run in Spruce, but then Spruce crashes out to the desktop after 3 %.
Any suggestions would appreciated at this point.
Thanks,
Patrick![]()
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
I wish I could assist in your DVD back up to DVD. I just backed up Goodfellas to SVCD however, and was pleased to find the following. Ripped each side to a folder , opened the side A files , appended the side B files. Total time still showed 72.5 minutes. On the bitrate tab, selected 1 CD for up to 75 minutes , but designated it as a 1200 mb CD. Hit go and ended up with 3 cue files of 805 mb for burning. Don't exactly understand how , but it worked.
When you say appended...
Did you just add the .VOB files from side b to the folder containing side A?
Didn't that overwrite a bunch of files? I thought that they had similar numbers, which is why I didn't try that...My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Yes , after loading side A VoB's by clicking on the folder, then I clicked on the dots to the right of the folder. Then I selected all 4 remaining VOB's and added. ( caution, required proper re-ordering ). File time still said 72.5 minutes, but after tricking the encoding bitrate as indictated, worked great. BTY , first tried to assign 1.5 discs of 800 mb , but it didn't like that, thus the 1 + 1200 mb.
mmm...
I wonder if I can just cut & paste the vob's from side B into the folder containing side a...My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
drdy111956:
Thank You !!!
I went intothe folder of side B, renamed all the vob's to have sequential numbers to side A, re-ran dvd2avi, reran TMPGenc and reran Spruce.
I just burnt my first test backup and it works fine!
Learn something every day.
Thanks again.
PatrickMy system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
