HI all I am new here...
I recently borrow an old movie from a friend of mine,..., it runs well in the VCD player...ok....but the problem is when I am going to play it in the computer, when I try to browse the CD, it shows no files at all!!! Although I can access the CD without any problem...
BTW media player cannot play it because there is no file to select,..as well WINDVD as so with PowerDVD...
I try to clone it with clonecd...it clones alrite but still no files in the image...can anyone help...thank you
The main movie in *.dat format should be located inside the folder called MPEGAV. Just load it into Media Player - it should be able to open it.
Yeah I know that....
But the problem is there isnt *any* files or folder inside the CD....the CD seems blank but it is not...
VCD with SWF files
By justdoit in forum Authoring (VCD/SVCD)Replies: 14Last Post: 28th Dec 2011, 20:45 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 17:21 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37
