I have a few MPEG-1 videos with size 480x576 which have been converted from AVI at 720x576. Is there a simple utility to convert the MPEG-1 files to 720x576 as the video appears "pinched"?
Cheers in advance,
Jus.
Results 1 to 9 of 9
These are PAL SVCD format. If you play them in a player that handle aspect ratios correctly, such as a software DVD player (Windvd, powerdvd) then they should be displayed correctly. WMP does no do this properly. Aslo, if you burn the to CD as SVCD and play on a standalone DVD player, they will look correct. No need to resize.
bugster,
thanks for that. WMP on my Win98SE Desktop does the correction (it has DVD-Rom). WMP on my XP Pro laptop doesn't (no DVD-Rom). Is there anything which will do the "stretch" and keep the same quality so I can view on the laptop without everyone looking very slim?
Cheers,
Jus. -
Juts install a soft dvd player and play them in file mode, both WinDVD and PowerDVD can do this, others too probably.
I tried installing WinDVD, but it requires a DVD-Rom to exist on the system (unless you know of a work-around!). I'll see if I can get hold of a copy of the other one and trt that.
Cheers. -
Windvd does not require a dvd-rom, you can play mpeg/dvd from your harddrive. I have installed windvd 3 demo and the latest 4.0 demo on a computer with no dvd-rom. Do you get any error when installing windvd or what do you mean?
An error messagebox appears at start of installation with "DVD-Rom not detected" (or something similar) and won't continue. It's a fairly old version, I'll have to check which tonight.
Is it an OEM version by anychance, one that came bundled with a DVD drive, maybe those require the DVD-ROM drive to be present. Try downloading the latest demo version of WinDVD or PowerDVD.Originally Posted by JusSmith
Equipment & Software Required To Host And Stream Live Video To Web
By wet bimbette in forum Video Streaming DownloadingReplies: 0Last Post: 26th Nov 2011, 04:18 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Video Encoding C++ Developer Required
By jsbelanger in forum ProgrammingReplies: 4Last Post: 23rd Mar 2010, 10:53 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Video Decoder info required. Thanks.
By seymoria in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2008, 23:02
