When I'm about to burn my backup DVDR in Nero i get the question If I want to burn Multisession or not. What is the difference between these ?
// Burlington
Multisession will allow you to add more files onto the disc at a later time. Not selecting multisession just means that the cd will be closed and you won't be able to put anything onto it in the future. If you're using a rw disc, however, then you can still format it and use it again. As far as I know, the only difference multisession makes is compatibility with older readers..
New problem with multisession DVDs
By SteveO_29 in forum Newbie / General discussionsReplies: 20Last Post: 22nd Jan 2011, 15:20 -
Two questions on multisession recorded disks
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 21st May 2010, 05:33 -
Will Nero 7.0 do a Multisession DVD
By scustalow in forum Software PlayingReplies: 6Last Post: 1st Oct 2008, 13:16 -
Closing Multisession tracks?
By When in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 05:15 -
multisession CD R???
By xiaofan in forum MediaReplies: 10Last Post: 11th Jun 2007, 05:12
