I am having problems using DVDecrypter, does anyone know of a guide to help. When I rip a DVD, and then play back on a stand alone DVD, I only get half the film. What should the settings be so I can get all the film.
Thanx
dude, read the guides here!
you could always try smartripper or clad to rip as well.
I have tried using smartripper, and it is ok for 1 or 2 disks, then when I try to create an AVI with DVD2AVI, it doesn't want to recognise it, or if it does TMPGEnc wont convert the file.
somethings going wrong in your process then I would have thought! I have ripped allot of dvd's and whenever I get a bug/glich/problem ripping it has always been because of user error. You'll be surprised!
try to have the least amount of programs running whilst you rip (although if you have a good enough processor (p3 900 or higher) it shouldn't matter). Keep your hdd's well defraged. Use a seperate hdd if you have one availble. -
Specs are:
AMD 2000, 2 x 120 Gig HDs (80 gig free), 796meg Ram, the only other thing running is TMPGenc and Win 2k. I am doing it the same way every time, sometimes works some times doesn't, hence I started DVDecrypter.
Numpty's Guide Please
By Dan Dare in forum Media Center PC / MediaCentersReplies: 7Last Post: 10th Dec 2008, 01:55 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 20:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 22:34 -
How to use Linux? Guide
By mjack425 in forum ComputerReplies: 2Last Post: 24th May 2007, 22:55
