After I convert and AVI to MPEG with Ulead Movie Factory and burn it, I get random bad blocky pixilization. Any ideas?
Is video source quality good(garbage in - garbage out)? What is the source?
Are you creating VCD,SVCD or DVD?
We need information to be able to help. -
If it's MPG1, open the file in TMGENC, click on file->mpg tools, merge and cut. Load the mpeg file, and select the appropriate file type in the top of the window (VCD, VCD non-standard, etc. This is THE most important part), and save the file with a different name. TMEPCG will demux and remux the file and will add the correct headers.
I had this exact same problem a few months ago and this is how I solved it. -
romu,
I will try that tonight.
The source is not very good quality but does not have the described problem. I am creating a DVD movie. -
Nay, it is garbage in garbage out problem.
Re-muxing it won't help.
It is same as a scratch LP problem. -
If the source does not have the problem, the output shoud not. If it's a random problem that occurs only when playing on a standalone dvd player, it indicates a problem the file headers.
The solution should work.
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 19:42 -
can you help ...ulead...mpeg... blocky
By newbie44 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2008, 07:43 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 01:49 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 18:25 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 14:30
