  1. Banned
    Dec 2001
    hey there i need some help trying to fix
    my hard drive i know some of u know the same
    about vcds as youll do about formating a hard drive
    (the old pc dose not have any cd-rom)
    (new pc haves cd-roms)
    my old pc stoped working cuz the hard drive got f$$k up
    and i tryed to format it in the old pc no luck.
    so thin i started to think how can i format the old hd.
    And bingo it came to me. Why i dont just plug in the old
    hd in to my new pc and format it from there so i did it was
    all going good the win98 startup disk was working and it formated.
    And i started on the setup and Boom there it was i know that it was to
    easy. It told me i cant install windows 98 cuz am runing a newer os windows me
    so can any of u tell me what i can do to install windows 98 back in
    to my old hard drive
    p.s. is there a program out there that can lit me add a os like windows 98 in to a 2ed hard drive to that i can put it back in to my old pc
    Oct 2002
    Dominican Republic
    try copy the windows 98 cd to your old disk, then run it from there on your old pc. you can use a floopy boot disk to start your machine, or put the boot files of the disk on your old disk.
    i have a problem let me know
    This is the last day of the rest of your life
  3. Sounds familiar. IMHO, it is Your ME boot disk, what causes Your problems. And if I'm right, the only thing to do is to get boot disk of either 95 OSR2 (with FAT-32 support!), 98 or 98SE with MSCDEX ofc.
  4. Member WishMaker's Avatar
    Florida, USA
    I downloaded Windows 98SE Boot Disk from somewhere. I do have it on floppy too, but one of my computer's doesn't have a floppy drive and I was going to make a boot disk on cd.
    I'll try and see if I can find the URL where I downloaded the book disk from. I use refdesk.com for searches on the internet. That's probably where I got it from.
    Thanks for reminding me I need to make that 98SE boot disk on cd, 'cause I forgot I had it and I need to reformat my hard drive. It's soooo full it acts like my Grandmother on drugs.
    Never discourage anyone...who continually makes progress, no matter how slow.
    Plato
