I capture a 15 min clip with Virtualdub and a dazzle usb. I used huffy codec and the avi was 1.69 gigs. If I take the file and encoded it with Tmpgenc, when I play it back it get a noise like the sound is already too loud and there is a static echo. I lowered the volume meter in Virtualdub, but I get the same thing. I download a vhs filter (cause I'm capturing from vhs tapes) I tinkered with the noise reduction and all, but I still get the same effect. The original capture though doesn't have that Static echo. I took the mpeg I had encoded with TMPGEnc,demuxed the audio,converted it to wav, and tried to re-encode it that way. Still the samePlease help out.
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum Capturing and VCRReplies: 1Last Post: 16th Nov 2009, 01:11 -
echo logfile question
By wiseant in forum ProgrammingReplies: 0Last Post: 17th Sep 2009, 19:42 -
Audio echo with new hdtv
By frankhb in forum DVB / IPTVReplies: 2Last Post: 4th Aug 2007, 03:08 -
Loud Static/Audio Clipping at end of Capture
By brandtb in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2007, 22:20 -
audio echo during capture
By caveman in forum AudioReplies: 0Last Post: 28th May 2007, 14:09
Please help out.
