  1. hi all i have all the tools needed to convert AVI to MPEG 1. my question is how do i find out what size my movie is (wide or full screen) so i can change it to what i want...widescreen. i have toyed with the settings in TEMPGEnc and don't want to waste a bunch of time and discs getting the right combinations to see the movie in widescreen
    thank you
  2. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Just set it to wide screen and use re-writable cd's to check if you like it. anyway, if you open TMPG wizard and drop the video in, the details come up in "aspect ratio"
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
    May 2002
    Rainy City, England
    You can't change a full screen movie to widescreen without losing some of the picture. The correct setting in TMPG is Source aspect ratio 1:1(VGA) and either of the *Full screen(Keep aspect ratio)* settings for Video arrange method.
