I want to encode my mpg's to avi to save space, i also want a program dat lets me edit da qualty of the mpg , like making it a letterbox, so when im done converting the output avi file will be avi, i have used Flask MPG, but it go es to 92% adn says runtime error, so i need a new one, thnx. pls msg back or emaeil me at pimpdaddy_4real@hotmail.com
thnx
try a newer version of flask, i had some problemz with .94
or so, and .6 or so fixed it (had a corrupted mpg file). plus it lets you crop, add watermarkz (havent tried it though), export, frameserv etc,..
* also, tmpgenc (tsunami) can output to avi,
* http://www.digital-digest.com/dvd/downloads/encoding_2.html#conv
Depending on the mpg file you have, virtual dub will sometimes let you import mpg filez, edit, and encode to avi, divx, etc....
zTr -
Virtual Dub is a great MPEG-1 to AVI converter. If you have a MPEG-2 file you have to use DVD2AVI and VFAPI in advance.
Thnx for da info, but i already tried FlaskMpEG and when im done encoding i cant open the avi file. what codec did u use to compress the video and the audio in FlaskMPEG?
pimpdaddy_4real@hotmail.com -
I also use virtualdub for this. You can use the crop filter, resize, all that, and change to any divx codec. It works great.
Liz -
V_Master,
use the divx 3.11 alpha codec. or the new divx4, which has multipass.
You couldnt open the avi in what? VDub or media player?
ztr -
I used Media Player to open my avi file dat i encoded. In FlaskMPEG da codecs i used to compress the video is the new divx4 and i tried da divx 3.11 alpha codec, and for audio i chose mpeg layer III, i wanna know what optinons u chose.
And i dun really like virtual dub, because it takes longetr and u can make da movie letterbox or edit it. Thnx for the help, msg me back
Whats the fastest video encoder?
By groggit in forum Video ConversionReplies: 25Last Post: 14th May 2013, 12:14 -
Whats the fastest FLV encoder?
By last_registered_user in forum Video ConversionReplies: 0Last Post: 9th Sep 2009, 23:17 -
vob2mpg and mpg2avi
By eliqush in forum Video ConversionReplies: 0Last Post: 5th Aug 2009, 11:36 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 19:58 -
whats a good program to use to convert/compress to h264
By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 19:28
