what is best cd media for burning videos onto (s)vcd's? also does anyone know best media for burned ps2 games as well?
After much research in this area, I concluded that it really doesn't matter
I prefer Fuji CDRs (or any of most other CDR brands made in Japan) because the pigment used in these discs seems to be more resistent to sunlight and fails less often while burning. Just my opinion tho.
Prospero -
Depends what you are using to burn the CD-Rs.
I have heard from reliable friends that you will get bad blocky pixelation on a standlone dedicated DVD recorder or VCD recorder unless you use high-quality certified error-free media. The same folks say the problem goes away when they buy name-brand high-quality expensive CD-Rs.
If you're burning video on CD-Rs on a DVD burner or CD burner, however, in my experience it doesn't matter doodly what kind of media you use. CD burners and comptuer DVD burners seem to be a lot better at handling marginal or off-brand media than dedicated standalone DVD recorders.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
media : blu-ray media range and more
By angel40204 in forum MediaReplies: 0Last Post: 8th Oct 2009, 07:14 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
