i'm gonna replace my current capture card and am in the market to purchase new. i need a card that will work with premiere, dont want any conflicts cause i love premiere 6.5. i will be capturing from vcr 99% of the time and would like to get it captured in a format that i wont have to convert over for premiere to import. it would also be nice to have vcr output, even though 99% of the time it will be vcd,svcd, or dvd output. looking for a pci card only, dont want to replace my nvidia geforce3 right now. also a card that doesnt cost a fortune and cause a bunch of conflicts would be great. ati, pinnacle and dazzle all have me kind of leary, heard and read to many bad things on adobes site. thanks for any advice
Today I ordered ADS Pyro ProDVD $109.95 from www.videoguys.com, comes with an outstanding software bundle. This is to compliment the Canopus ADVC 100 BJ_M refered to. I'm new to capturing, but am hopeful; I have made a wise choice. Time will tell!
Jim -
sounds like im gonna buy me a advc 100 card. whats a good price and where to buy? also, i dont have firewire on my pc, should i purchase a pci firewire card too( in case i get into more digital in the future) or does the advc 100 have evrything i need?
http://www.videoguys.com/canopus.htm $299 (you can find it a little cheaper (270$) but these people will give you support and help and if you have problems)
you will need a firewire card (PYRO Digital Video 1394DV)
http://www.videoguys.com/pyro.htm#pyro $69.00 is the right price ..
or the Pyro ProDVD $109 ..
use good cables -- !!
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 22:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 22:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 02:41 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 16:15 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
