i have a Pinnacle PCTV Rave TV tuner which also has an input where i can plug my VHS player or digital cam recorder. but i remember that the bundled software with it is hard to learn and eats up most of my CPU resources.
now, are there any freeware (or a limited trial one) program that i can use to capture straight to a VCD compliant MPEG1? pls advise. thanks people.
Try PowerVCR or WinVCR. They should have a trial version for downloading. The quality is not magnificent (not as good as TMPGEnc) but they'll do what you're asking.
Another option would be to capture using a program like Virtualdub and then encoding it to MPEG using TMPGEnc (which is free for MPEG1).
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
MPG File to VHS Tape?
By Coxjeet in forum Capturing and VCRReplies: 2Last Post: 6th Sep 2007, 04:12
