I am looking to capture some TV and convert it to a DVD for playback on my standalone DVD player and was wondering which of the following would give me the best playback quality.
I could capture in
720x576 25fps and 4000kbits/sec or
352x576 25fps and 7000kbits/sec
Both are DVD resolution, but one has a high bitrate, the other a high resolution. Bearing in mind that there are some fast motion/explosion scenes, I was wondering what would give the best quality.
I would appreciate your thoughts.
Many thanks,
Kevin.
hi
Don't u have any custom settings on your software????
I use 720x576 pal 750 bitrate on PowerVCR2.
Or DVD Pal on WinDVR2 which is 720x576 about 6/7000 bitrate.
Fozzee -
If you have a good source and are using good cables, Definately capture at 720*XXX you WILL notice a difference if you don't.
and don't forget a decent encoder chip on your card there is a big difference between them rankings are
first connexant
2nd chrontel
3 rd phillips best to view blank screens only -
Thanks for the advice guys. Bearing in mind what pharlap says, any thoughts as to what the best capture card to use would be ?
I am curently using a WinTV PVR which is giving me quite good results (but admittedly I don't have anything to compare it against). Could I be getting better results with a different card ?
Cheers,
Kevin.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
FCP 7: HD Playback with NTSC Sequence Settings?
By TeeHee in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 23:17 -
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 15:46 -
WMV settings for smooth playback
By sumario in forum EditingReplies: 0Last Post: 3rd Jul 2008, 21:31 -
best Super settings for slide show playback
By alldigitalsupport in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Apr 2008, 13:21
