I bought a LGV-5480TVR tv tuner and video capture card (from ebay). It was factory sealed and came with the original software. I installed it and was able to view both TV reception and the video from my camcorder..
THE PROBLEM IS I CAN NOT CAPTURE THE SOUND!
It gave me an error upon compleating instalation that there was a problem in configering for sound capture and told me to see the users manual to fix it.. problem is it is all in Japanese.
Everything else seems to work great..
Can anyone help tell me how to correct this problem please???
Results 1 to 1 of 1
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
No sound problem - internal tv capture card
By planetx in forum Capturing and VCRReplies: 1Last Post: 5th May 2008, 05:38 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
