I'm burning an XVCD in Nero, ive made a few before but only a min or so to test some settings. now about 5minutes into the burn, i get the blue screen, then nero says "buffer underrun" and the burn stops. whyyyy
No need for a technical analysis to understand it. Buffer Underrun just happens when you've got too much going on.
So now, when you're burning, close all your programs (ctrl-alt-delete) and just let it burn. You can also cut your speed a bit, maybe halfway if it doesn't matter to you (if you burn at 8x, you could cut it to 4x) which will cut down on buffer underrun possibilities.
Or just get a newer burner w/ buffer underrun protection (which I don't know to much about - I don't own one of those).
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
Help: ImgBurn Buffer Device @ 59%
By butt_crack in forum ComputerReplies: 2Last Post: 5th Feb 2010, 17:22 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
buffer size question
By socalkev in forum Newbie / General discussionsReplies: 0Last Post: 26th Sep 2008, 16:36 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 16:08
