  1. Does a 2.09 max bitrate convert to 2090000 when using MMC reg tool?
  2. yes for bitrates between 9.9 and 1.0 you use 7 digits
    2090000 = 2.090000
    the program will check the max and mid ranges so if you accidently enter 2.09 it will tell you thats not correct
    -Stinky
