Hey guys, new guy here, was just wondering though how long it would take a ASF file to convert to a MPG file, I tried it one tonight, it was a 20 minute ASF file, I went to the store while it was converting and came back, it said it only had 1 hour and 20 minutes to go, but I started checking my e-mail etc, then it went all the way up to 3 hours and 40 minutes, Am I not suppose to be running anything during the Conversion? Im also using TMPEnc, Any help would be appreciated.
Dont Run, You will only Die Tired.
What is your system? What type of compression is the asf using? I am running a 900 t-bird and It can take a while but it all really depends on your processor speed. When I upgraded to 256mb ram it didnt change how fast it was going, not even by a hair.
I am running a AMD Athlon 900 mhz pc with 128 megs of ram.
Btw, how do i find out which type of ASF im using?
Dont Run, You will only Die Tired. -
Yes, it's normal for encoding time to increase when using other applications while encoding. Since your RAM is quite small (yes, 128MB is minimum these days) and TMPG is VERY CPU intensive, the encoding time will increase.
I've got 384MB and the same thing happens to me, although not by that much.
How long have emoticons been around?
By yoda313 in forum Off topicReplies: 5Last Post: 23rd Jun 2011, 09:40 -
How long to accept it ?
By logandu62 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Apr 2009, 15:18 -
A long overdue thank you
By epj16706 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 21:03 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 19:08 -
Why does it take SOOOO long?
By someonesomewhere121 in forum Newbie / General discussionsReplies: 7Last Post: 25th Mar 2008, 10:20
