The Pioneer DVR-A04 or HP DVD100i
Thanks and please tell me why you think one is better than the other.
DVD-R is not more compatible that DVD+R, they are about the same. Having Said that Do NOT buy the HP DVD 100i as it does not support DVD+R, only DVD+RW.
If you do decide to go for DVD+RW and want to buy HP then buy the HP DVD 200i. Sony have a drive that will burn both formats although many people seem to be having problems with the Sony drive. -
I would say that the best two on the market are the
DVR A05/105 Vs. Sony DRU500a with the DVR A04/104 comming in a close third.
Personally I would buy the Pioneer DVR's before the sony only because I never invest in first generation technology ( first dvd-+rw ). If price and compatibility are you two driving factors than the DVR 104 is a good choice. I picked up the CenDyne ( Pioneer 104 ) for good price of $199.
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 25th Feb 2011, 00:41 -
Recommend a new dvd recorder
By colt4523 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 29th Aug 2009, 00:02 -
What burner would you recommend?
By taboo in forum MediaReplies: 33Last Post: 5th Jul 2008, 13:01 -
Which DVD Recorder would you recommend?
By DJL82 in forum DVD & Blu-ray RecordersReplies: 48Last Post: 30th Dec 2007, 12:44 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
