Hi
I can't join AVI files because their Sampling Rates are different.
-The Frame-rates are the same, 29.970fps
-Am using VirtualDub.
one set are 8000hz and the other are 24000hz
Could someone tell me ,
What is Sampling Rate & How does it play a part in Joining.
This is the error message that VirtualDub Gives:
cannot Append AVI segment. The audio Streams have
differrent sanpling Rates.(1000.00000 vs. 5998.00000)
Any solution?...advice,...information.
Thankyou.
______________________
Rainstar.
Load iniatialize and use AviSynth to join the two files. The "+" operator does nopt care what sampling rates your videos are.
Hello. -
Hi.
Thanks! Tommyknocker.
-Know what effects these sampling rates have on the joining process ?
___________________
Rainstar. -
Well, obviously, the audio in the two avi's was produced with different sample rates. It depends what you intend to do with the AVI as to wether TommyKnockers solution will be appropriate. I am not sure what would happen with such an avi if, for instance, you tried to re-encode to mpeg with TmpGenc. I have a feeling the audio in the resulting mpeg would be all screwed up.
Use virtauldub to convert the sampling rate of the audio in one avi to the same as the other.
Audio->full processing mode
Audio->Compression-None
Audio->Conversion-> new sampling rate
File->save wave
Now do Audio->wav audio (select new wav file)
Video->direct stream copy
File->Save avi, and save a new copy of the avi
Repeat for second avi and join.
If you intend to re-encode to mpeg, this is sufficient
If you want to save the avi, load the new (joined) avi
Video->Direct stream copy
Audio->compression (select codec)
File->Save avi
That should do it, bit long winded tho.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 06:46 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 06:07 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03 -
Join 18 .avi files with VirtualDub
By nlec in forum EditingReplies: 8Last Post: 16th Jun 2007, 00:32
