Hey guys,
I'm new to this stuff and could really use some help with premiere & VCD's. I'm capturing 1 hour mpeg1's with my capture card (of simpsons) and editing out the commercials: comes to about 28 minutes. Figure I can get 4 or 5 episodes per disc.
The original capture size is usually around 450-600M. After I take out the commercials and render the size is 3or4x's as big! What gives?! What settings should I be using?
I'm rendering out:
- 352x240 (NTSC)
- .mpg 75% quality
- 44hz 16bit audio
- 29.97fps
- Data rate: recompress (off)
I like the quality that is being captured and am trying not to "double compress" everything, just take out the commercials. Any help is appreciated.
Try to frameserve to TMPGEnc (read the tutorial in this forum). Usually 1 min of video requires 10MB of disk space for MPEG-1 VCD format.
hi vcdfreak - yes i realize that it's about 1min:10M for VCD so that's why i was wondering what settings to use i.e. - my resulting renders are ridiculously large!
what my real concern was that in editing out the commercials, that means i have to render out the movie in premiere - and i don't want to have to re-render it AGAIN in another program. so what settings are you guys using in premiere?
thanks! -
That's why you need to frameserving and export frames to TMPGEnc.
Encoder comes with premiere usually behave quite differently. I assume you are using the Ligos plug-in which allows you to set a lots of parameter. I hope you are exporting to MPEG-1 instead of MPEG-2 format which will blow up the file size a lot!
Need to export movie in Premiere Pro 1.5. What settings?
By vid83 in forum EditingReplies: 5Last Post: 23rd Mar 2013, 17:13 -
Settings for Premiere smart render/how to tell if it's working...
By rcavanah in forum EditingReplies: 8Last Post: 14th Sep 2011, 18:20 -
default settings to export quicktime in premiere
By kidkunjer in forum EditingReplies: 0Last Post: 16th Sep 2010, 02:03 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Best HD settings output from Adobe Premiere for Youtube...
By mhdeaton in forum Video Streaming DownloadingReplies: 4Last Post: 11th Nov 2009, 23:15
