    Nov 2002
    east brunswick
    HI please help me i am having problems capturing and burning with nero vcd maker i have used this for a while and it works fine with divx codes but not with xvid....
    is there something that i am missing? or not doing correctly? please let me know.
    Apr 2002
    The State of Frustration
    Suggest you encode it with TMPGEnc to the appropiate template, and burn the resultant file. Then Nero should encode it properly.
    Hello.
  3. ur not totally wrong there tommyknocker m8, id suggest the same thing...so i do, go wif tmpgenc...n i also think that this thread should hav been written in "Capturing" forum n not "Authoring" cus its really more bout capturin to b honest, but as im a nice lad im just happy to give u sum help..
    Nov 2002
    east brunswick
    Thanks!! im gonna try it ^^ :P
  5. np just happy to help m8, if u need ne more help just tell me...
  6. *lol*, i got a puter bout 2 hours ago but i need help to do sumfink which i fink is hard, there are nuff buttons on the axual puter, wot do i press to put in a vcd pls?
  7. r u tryin to b funny or summit? on ur computer there u should b sum button that will eject ur cd/dvd-rom, when its open u put ur cd/dvd in n then press same button as u ejected it...i really hope ur tryin to b funny hehe otherwise go to sum computer course lol
