I think I understand that interlacing breaks a frame into 2 fields, even and odd, and then alternates them on a TV screen. The question I have is handling this interlace from capture, through editing, and then playback.
I am capturing analog hi-8, which I presume is interlaced, and capture as AVI 640x480, mjpeg. I want to edit through MediaStudio 6.5 and then push out to VHS tape.
The questions. Should I de-interlace or do any kind of vertical reduction? If so, should this happen during capture?
Live every day to the fullest as if it is your last, because someday it will be.
I would deinterlace if you are going to view it on a progressive (like your computer monitor) display. Otherwise, I'd leave it alone.
Clarification:
If I want to edit and then output to VHS tape, then it makes no sense to de-interlace, right?
I capture hi-8 NTSC through virtualdub, 640x480 AVI, mjpeg=18, sharpen=15. That's interlaced, correct?Live every day to the fullest as if it is your last, because someday it will be. -
Don't know why you have to output it back to VHS tape. You must have a very good reason. Tape - AVI - Tape again?
If you convert it to MPEG-2 stream, there is no need to de-interlace. I would imagine the same for tape, although I have never done it. -
Why not just go from your HI-8 player direct to VHS. If you use a VHS deck with flying erase heads you can edit on it and you'll have a first generation copy and flying erase heads will assure perfect edits.
I want to edit the captured AVI file using MediaStudio 6.5. The reason I'm going back to VHS is because I'm sending the end product to relatives and friends who don't have DVD players or computers.
I'm pretty sure if I capture at 352x480, AVI, mjpeg=18 then MediaStudio can handle the 2 fields correctly. In other words, playing this interlaced capture on the PC would look crappy. But editing and then outputting to VHS would look ok.
Sound about right?Live every day to the fullest as if it is your last, because someday it will be.
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 02:33 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 10:20 -
VirtualDub De-interlace
By Lee82 in forum EditingReplies: 16Last Post: 25th Feb 2008, 18:57 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 15:14
