  1. I have TMPGEnc and i'm trying to change avi to mpeg. But when i select the avi file. It says it cannot open or is unsupported. When i looked at my avi file under properties, it says unknown format. Anyone know whats going on? or if i can make vcd using avi files?
  2. Maybe the avi is a DivX movie? Try installing the DivX codecs. You can find them in the tools section on the left. DivX movies have the avi extension too.
    Regards,
    Willem
  3. Like Willem said make sure you have the DivX codec installed. You can double check buy trying to play the file with Media Player.
