hello, i am having trouble editing a vob, i want to cut the end credits off a film so that it will fit on to a dvd-r, i cut the last vob up with vobedit but when i go to play it back in powerdvd it will not play, what am i doing wrong?
SneakyG
-Girls best friend- -
I dont know whats wrong with vobedit, but i use Chopper XP and it works fine for me, just a slight problem using ifoedit 0.94, but if you arnt using this then it should work fine.
Thanks for pointing out this software. I will give it a try tonight.Originally Posted by Mr N
Chopper XP is a tool that lets you extract a part of a Vob file. It is a DVD cutting program with a great interface and very fast speed of operation. You can scroll to a location and select mark in and out points and save the file as a Vob file. The program also lets you set any priority of extraction and displays the estimated time left for extraction.
http://www.digital-miner.com/ -
ive used choper xp to cut the vob, but it will not play in power dvd, why? how can i use the vob?
SneakyG
-Girls best friend-
Edit .VOB
By willmington in forum Newbie / General discussionsReplies: 11Last Post: 2nd Nov 2010, 04:59 -
How to edit a VOB file
By Piatti in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2009, 16:20 -
I want to edit one VOB file.
By happydog500 in forum Video ConversionReplies: 1Last Post: 21st Jun 2009, 21:36 -
Edit alone the vob
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2008, 02:23 -
edit .VOB files
By vali in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2008, 04:23
