When trying to making the backup copies of my new purchased DVD, I discovered that the process I have been using for so long did not work any more. There was no problem in video, the problem was in encoding LPCM audio. The wav files generated by DVD2AVI has a high pitch, and sounds like at double the speed as it should be. All the DVD's were released by EMI recently. I am wondering if it is a new encryption scheme.
I would also like to know what software tools were available to replace DVD2AVI to encode the audio?
I have tried a few rippers, such as SmarterRipper, DVD Decrypter, etc. and received the same results.
Any help and suggestions would be greatly appreciated.
Ming
no new encryption on the audio front at least - because just recording the audio real time is easy anyway .. and for some hardware issues - basicly how would you get all older dvd players to play the disk?
i suggest you have a codec isssue and i would remove - then re-install all ac3 codecs/filters and releated apps . .. -
BJ,
It really purzzled me. I tried on three machines, all have similar settings and have been doing the job without problem until this disk set. There were no problems to play those disks in standalone players or play the ripped files on computer. There must be something that DVD2AVI does not handle right.
I will give FlaskMPEG a try to see if it can handle it.
Thanks,
Ming
Rip DVD with DTS under LPCM
By ddtof in forum DVD RippingReplies: 8Last Post: 29th May 2012, 07:44 -
LPCM 1.0 - is it legal for DVD?
By Alex_ander in forum Authoring (DVD)Replies: 4Last Post: 29th Sep 2011, 03:09 -
Help - LPCM 24 96 to DVD
By JorgeO in forum AudioReplies: 5Last Post: 10th Aug 2011, 08:47 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
How to replace LPCM by AC3 before shrinking a DVD
By cd090580 in forum User guidesReplies: 30Last Post: 24th Dec 2009, 21:47
