hey there i need some help trying to fix
my hard drive i know some of u know the same
about vcds as youll do about formating a hard drive
(the old pc dose not have any cd-rom)
(new pc haves cd-roms)
my old pc stoped working cuz the hard drive got f$$k up
and i tryed to format it in the old pc no luck.
so thin i started to think how can i format the old hd.
And bingo it came to me. Why i dont just plug in the old
hd in to my new pc and format it from there so i did it was
all going good the win98 startup disk was working and it formated.
And i started on the setup and Boom there it was i know that it was to
easy. It told me i cant install windows 98 cuz am runing a newer os windows me
so can any of u tell me what i can do to install windows 98 back in
to my old hard drive
p.s. is there a program out there that can lit me add a os like windows 98 in to a 2ed hard drive to that i can put it back in to my old pc
