Im using TMPGE and a few templates to make some vcd's and have a setting question. Some of the guides I have found on this site say to change the advanced>system>streamtype to mpeg1 nonstandard. Why is that? And do yo always have to uncheck the "make standard compliant" box in Nero?
John
If you use any template for VCD other than the ones that come with TmpGenc, chances are they somehow break with the strict VCD standards. Thats why you have to
and why you have to uncheck compliance in Nero.change the advanced>system>streamtype to mpeg1 nonstandard -
This is only used if you use Nero to encode (bad move) rather than to burn.And do yo always have to uncheck the "make standard compliant" box in Nero?
What's the new standard?
By wild4trv30 in forum EditingReplies: 6Last Post: 31st Jan 2010, 11:39 -
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 19:26 -
Is there really such a thing as "standard mpeg 4 video"?
By yoda313 in forum Portable VideoReplies: 5Last Post: 25th May 2008, 13:16 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 07:09
