  1. I've never run into this before, so I've never had to to this, therefore, I don't know how, but I am willing to learn.
    I've downloaded a movie file which was in the bin/cue format. I converted it to the avseq01.mpg then converted that to the 2 img files via GNU vcdtoolsX. Unfortunately, I trashed the bin/cue and avseq files before I started to burn the resulting img files with toast. When I went to burn it, I found out that it is some 91 odd minutes long, therefore it won't fit on a CD.
    Is there some way that I don't know of to make this fit? From the files I have, can I somehow edit the file itself to remove maybe the credits (its disk 2 of 2)?
    I would appreciate any help in this you could give me. Thanks.
  2. if you have qt pro, open the mpg in that, set the in and out points either side of the part you want to remove, and just hit delete Then just resave your file.
